Old 05-23-2007, 06:48 AM   #1
How to make working push-buttons from the blank pieces
Blank Button Mod
Modify the blank switch buttons like this.
- Details -
I looked around the web, and there are a lot of spare switches to be found, ranging in price from about $45, to $100.
Being a bit more resourceful, and daring, I decided to make my own switches from the blank button fillers.
I removed the ceneter console switch panel, and removed the blank button cover.
They are easy to release.
I used a Dremel tool to slice off the top of the blank button, slicing about mid-way along the egde.
I used a small push button on a circuit board to form the button base. I got this from some old used scrap electronics.
I used the Dremel to cut away the PCB, and fitted it to the back of the button bezel. It slides in nicely over 2 bosses in the plastic after cutting 2 notches in the PCB. Epoxy cement holds it in place.
I glued the top of the false button onto the plastic housing of the switch, leaving room for switch travel.
Here's a shot of the completed garage door opener button in place.
Clem-Clone is offline   Reply With Quote
Old 05-23-2007, 06:56 AM   #2
Very nice. I know you can find those type of electic on/off switches at your local radio shack too. I did the same mod for my extra set of fog lights.
Old 05-23-2007, 08:11 AM   #3
nice job - very well documented and informative.
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
Old 05-23-2007, 06:55 PM   #4
thx dude, thats an awesome write up
Old 05-23-2007, 07:25 PM   #5
There Is No Substitute.
rick3000's Avatar
That's awesome, but aren't the stock switches flat not curved?
Old 06-18-2007, 09:42 AM   #6
rick3000's Avatar
I hate to bump an old thread, but could you update the pictures. I would like to try this mod.
Old 06-18-2007, 04:33 PM   #7
pics work fine for me
Old 06-18-2007, 04:57 PM   #8
boxsterz
Nice work! I likey.
Old 06-19-2007, 07:53 AM   #9
rick3000's Avatar
Thanks, it must the new Safari 3 browser.
This beta version is horrible.
Old 06-19-2007, 02:49 PM   #10
donv's Avatar
I don't think that's it. There appears to be a DNS or server availability issue with where the pictures are hosted. When I try
http://jbipes.home.comcast.net/jpgs/boxster/switchconsole.jpg
I'm told my ISP (interestingly enough, comcast as well) can't locate the server.
If I try enough times, it eventually works. For instance, I couldn't see the pix myself,
but when I started this reply they actually appeared in the thread below. Go figure.
Old 08-17-2007, 03:21 PM   #11
Clem-Clone,
Thanks for this, I just did a couple of blanks in the dash for the onboard computer hack.
One small difference I did. If you can find some short travel pushbuttons you can only cut through about 80% of the blank top leaving the rest as a "hinge".
Keeps everything nicely lined up.
Back to the shadows again.
Steve
coloradosteve is offline   Reply With Quote
