07-01-2007, 06:30 PM
www.klisstle.com
Pedal Medal
I've had a set of inexpensive pedals for a couple of months and didn't have much desire to install them. Well, finally this weekend I gave it a go. I also sanded and painted the fuse cover panel. It looked like the original owner wore golf spikes and scraped the panel when entering and exiting the car.
Here's the before:
Here's the after:
ddb
07-03-2007, 03:49 AM
Man those look great, nice job! Was the drilling for install hard? Your Boxster keeps looking awesome!
07-03-2007, 06:21 AM
Inexpensive to you is expensive to me  , those are nice pedals!
07-03-2007, 01:16 PM
www.klisstle.com
Thanks guys.
I had read about how difficult it would be to drill through the brake pedal, so I was prepared. My cordless drill isn't that powerful, so I didn't even try to use it. I just broke out my seldom used old electric drill. On top of that, I bought a new set of drill bits. I then took advice I read here or on another site and started with a very small pilot hole, and enlarged the hole with different drill bits until reaching the desired diameter. Lastly, I removed the plastic owner's manual holder under the steering wheel in order to get a better angle with my drill. After taking these steps, it was rather easy to drill the holes. I made marks on my rubber brake and clutch covers and drilled through rubber before going through the substrate. I believe the rubber acted as a guide and prevented the drill bit from sliding around on the metal or plastic.
I hope these tips will be helpful to the next guy.
ddb
Edit - I forgot to say that I didn't use the rubber brake and clutch covers in the final install. I used them as guides and removed them before attaching the metal covers.
07-03-2007, 02:28 PM
Do you mind me asking where you got them and how much they cost?
07-03-2007, 03:47 PM
www.klisstle.com
No problem. I bought them on eBay for $69.99. Shipping was rather high at $25.00. The seller's name is orangehuang531.
ddb
07-07-2007, 03:28 PM
gas pedal question
i poped my gas pedal off and now I can't get the ball back in the cup on the back of the gas pedal, do you know how to get it reconnected/
07-07-2007, 04:41 PM
www.klisstle.com
Sorry gpminow, no experience reconnecting the gas pedal. I'm sure someone with knowledge will chime in.
Good luck, and post some pics when you're done.
07-07-2007, 07:46 PM
Very nice, ddb. The new pedals are a much-needed improvement over the stock ones. If you don't mind me asking, how much did you pay for the set? I assume the set of three came with the dead pedal, too?
07-07-2007, 09:16 PM
Very nice!
07-07-2007, 09:20 PM
Here ya go:
ddb
07-14-2007, 10:40 AM
Originally Posted by chaudanova
Here ya go:
Duhh. Sorry. I don't read; I just look at pics :ah:
07-14-2007, 05:21 PM
Pedals
Looks great! Can I ask, did the aluminium pedals raise the pedal height? I am ~ 5'10" and was wondering if I did this would it feel to high? Thanks
07-14-2007, 10:15 PM
www.klisstle.com
Hi kelsey,
Thanks. I drove the car for the first time since installing the pedals 3 days ago. I'm about 6 hours away from home and didn't notice anything odd about the pedal height on the drive. I removed the brake and clutch stock rubber covers which probably offset any net gain in pedal height.
On longer distances I like to drive with my shoes off (socks on). The only thing I noticed is the nice feeling of the raised pieces on my feet when depressing the pedals.
Post pics if you decide to add the pedals.
ddb
07-15-2007, 10:34 AM
What did you like better on the other set. The only thing I noticed was Porsche written a it bigger. Is there a slight different in finish?
07-15-2007, 02:26 PM
www.klisstle.com
Hi SC986,
Two things: The raised pieces appear to be cylindrical and made out of rubber on the set in the link. Mine are plastic and domed shaped. I think the cylindrical set looks better.
Also, mine are attached with just 2 screws per pedal, versus 3 on the set in the link.
Did you get your top? How do you like it? Pics!
ddb
07-15-2007, 03:57 PM
Yeah got the top painted and on last Thursday. I like it, it really gives the car a different look. I need to do some adjustments, have alot of windnoise on the drivers side.
I tried for 45 minutes today and could not get the plug for the defroster clipped in..Grrrr.
Yeah, I haven't taken a pic yet. You know the area, no great scenery around. I need to though!
07-15-2007, 04:26 PM
Hmm, I like it - might have to look into a set for me.
07-15-2007, 10:19 PM
www.klisstle.com
SC986:
It's a bear to get your hand contorted enough to plug in the defroster cable. Keep trying and you will get it in. Looking forward to seeing the hardtop.
Dr. Kill:
For the money I think those pedals offer a great bang for the buck! Post some pics if you decide to install a set.
ddb
HTML code is Off
