Old 12-21-2007, 12:56 PM   #1
Smile Opinions on RPM's
My RPM gauge redlines at 6200 (roughly). I do NOT do the following but would like your opinions. Is it harmful to the engine to routinuely rev up to 5000 RPM's before shifting up to the next gear. A salesman told me during a test drive to only shift up after passing the 4000 RPM mark. That was with a 2005 Boxster, I have a 1998, if that makes any difference. I look forward to your opinions. Thanks..
gmboxster is offline   Reply With Quote
Old 12-21-2007, 01:09 PM   #2
bmussatti
My car redlines at 7,200 RPM. I do a lot of shifting north of 5,000. Except from 1st to 2nd. I don't want to get whiplash!
Old 12-21-2007, 01:10 PM   #3
Its safe. Reving it over 4000rpm once a day is actually healthy for the engine. Keeping it over 4000rpm all the time like road racing wears out the engine faster depends how good the motor oil you use.
01 Boxster S, 04 MINI CooperS, 04 WRX Wagon (Track Only)
http://img.villagephotos.com/p/2003-7/281816/986sig.JPG
Back2DTM is offline   Reply With Quote
Old 12-21-2007, 01:12 PM   #4
rdancd816's Avatar
I drive a '97 2.5. I wil not rev the car above 4000 RPM's until fully warmed up. After hitting the 180 degree mark I rarely shift below 4000 RPM's. That's the power curve sweet spot on the engine. Power mangement is what makes the 2.5 a lot of fun. It's not a rocket, but it does deliver good performance if managed properly. Experiment a bit but respect the machine. IMHO!!
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
rdancd816 is offline   Reply With Quote
Old 12-21-2007, 01:15 PM   #5
My car is perfectly happy shifting at low rpms and it loves high rpms too. That is one of the things I like about these engines, they are so linear.
I was cruising in town the other day at 35 mph and pushed down on the gas, car accelerated fine, then I looked down and noticed I was in 6th! Unbelievable how smooth and how much power is available even at those low rpms.
I think the dealer that told you above 4k rpm just wanted to help sell the car. I would say you don't want to "lug" it by always being in too high a gear on a regular basis. But beyond that, these cars are made to both drive subdued and sportier high revving driving, so both should be fine. People often say that is one of the things about boxsters and 911s is that you can use them every day compared to some of the more high strung cars.
saaber is offline   Reply With Quote
Old 12-21-2007, 01:36 PM   #6
like rdancd816 said, make sure your engine is up to temp before high revs. i personally shift at 3K RPMs until the engine is warmed up. then, it's whatever the situation demands. i hardly ever shift past 6300 RPMs because you can grab a higher gear and still stay around 4K RPMs where the torque peaks. although, i have to admit that i've hit the rev limiter in 1st gear several times just from having too much fun.
03 Boxster S | EVOMS intake | PSE | B&M shifter | Softronic ECU tune (traded-in)
03 911 C4S | Softronic ECU tune
texwayne is offline   Reply With Quote
Old 12-21-2007, 01:42 PM   #7
blkboxster
after im warmed up, i always shift above 4000 rpm
Old 12-21-2007, 02:10 PM   #8
The variocam kicks in at 4200 rpm on our 2.5's; the car is designed to be driven in the 4-5k rpm range.
I run mine up to 6k routinely when I take it out to drive the car for the sake of driving the car.
I don't keep it at 6k though while cruising at any speed. No sense wearing out the engine.
Conversely, wearing out my engine would give me a great excuse to put a 3.4 in it!
Old 12-21-2007, 02:59 PM   #9
There Is No Substitute.
rick3000's Avatar
When the car is warming up I shift below 4K and cruise at about 3k. Once the car is warmed up I shift between 4K-5k, unless I am out to just drive, then I'll shift between 5k-6k. I normally cruise between 3k and 4k.
I didn't know that. It sounds like it would strain the engine to cruise at that high an RPM. But if you have a valid source, please post it. Maybe I should change my driving style.
Old 12-21-2007, 03:12 PM   #10
The car is meant to be driven hard, but not abusively. Like other said, wait until the water temp is 180 deg. F before going over 4K. E46 and later M3's have this restriction built-in, wouldn't be a bad idea for Porsche. Once fully warmed up, you shouldn't be afraid to be north of 4K, for a car out of break-in.
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
pbanders is offline   Reply With Quote
Old 12-21-2007, 03:35 PM   #11
Sabre, there is no way you were going 35 in 6th, and certainly no way it accelerated well. If I did that I would be ready to stall!!
MrNiceGaius is offline   Reply With Quote
Old 12-21-2007, 03:45 PM   #12
How wrong you are. I came off the highway and leasurely cruised into town and flowed with traffic dyadreaming and never shifted down... and it did accelerate just fine and was not about to stall at all.
I wonder if a person could start in 6th and go to 162mph in one gear? Now that would be something. It probably can't be done but maybe in 5th? Not willing to burn my clutch to try but it would be interesting. These engines are amazing.
Old 12-21-2007, 04:27 PM   #13
If you look in your manual there should be recommended shifting RPMs. At least there was for my 99'. I believe it was 3k-3.2k depending on the gear,for everyday driving.
Psh,4 & 5k rpm,that's nothing I'm starting to get closer and closer to 6k every on-ramp and the car loves it.
Old 12-21-2007, 04:33 PM   #14
As long as the vehicle is within the correct operating temperature ranges (typically between 160 and 240 degrees) feel free to use all parts of the tachometer range, up to redline. On my 2000, it had a 7200rpm redline and pulled great from about 4K rpm till redline. I could shift at 3k rpm or 7k rpm.
I would like to see quantified just how much you would "wear out the engine" by using the designed for operating range. Seems a bit hogwash. Like when the first V-8s were invented, folks wondered how you wouldn't "wear out" the bottom side of the pistons. It just doesn't happen.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 12-21-2007, 04:38 PM   #15
mines tiptronic so i put my foot down on the pedal, the needles goes all the way to the redline then it changes. im sure if this was a bad thing then all the boffs at porsche would have changed the gear change.
people that never go over 4000 revs on an engine that will go to 9000 dont deserve there car and i imagine drive like ****************e
deano_123 is offline   Reply With Quote
Old 12-21-2007, 04:56 PM   #16
Well since you admited to driving slow.. the torque you felt at 35mph in 6th gear felt fast enough to you while it wouldnt to some of us that routinely hit the 4k rpm range to feel that torque against our backs and asses.
Thats probably why it seems good enough for yah.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 12-21-2007, 08:11 PM   #17
Don't know what you are talking about "driving slow". I rev over 4k often if for no other reason to hear that sweet sound above 5k or so and I shift at the redline when driving fast. I was talking about how the engine has amazing torque even at ridiculously low rpms.
Old 12-22-2007, 03:45 AM   #18
TOP GEAR BBC did a demo starting in 5th but ran out of road before redline. speaking of revs @ track days i'm having a hard time shifting to 2nd from 4th whats a safe # in 3rd. or if your in 3rd and slowing it's always safe to pull 2nd. 2002 S stock.
986chris is offline   Reply With Quote
Old 12-22-2007, 06:25 AM   #19
Brucelee's Avatar
Smile Taken from an engine patent application
Well-designed conventional reciprocating engines operating at conservative powers and speeds, irrespective of size or type, generally last about 5×108 revolutions before wear-out of the piston rings and the cylinder bore. Note that the engine life expectancy is a function of the number of revolutions rather than the total piston travel distance. Such a fact implies that wear-out is primarily due to the ring reversal event, i.e., the reversal in direction of ring travel that occurs twice each revolution. It is well known that maximum bore and ring wear occurs at ring reversal due to the "squeeze-out" of the oil film between the ring and bore when the ring is not moving.
Also, higher piston speed increases wear rates because of the increasing difficulty in maintaining an adequate oil film. It is generally accepted that average piston speed should not exceed about 2000 feet per minute, and low speed engines enjoy a life advantage over high speed engines.
As can be seen from FIG. 3, as engine speed increases, the frictional horsepower losses become quite significant in the conventional engine
Rich Belloff
Old 12-22-2007, 06:32 AM   #20
Brucelee's Avatar
From an engine builder
Piston Speed
Vehicle speed and engine speed are both obvious quantifications we consider every time we turn the ignition over and step on the gas. But piston speed is something just as important, and is more often than not forgotten about.
It's usually measured in feet per minute and is the rate at which the piston travels up and down the bore. But the rate changes, as you might expect, alongside rpm changes.
At high rpm, the piston can reach speeds over 100 mph as it nears the center of the cylinder and then slow down to a near stop at the top or bottom of its stroke. It's not hard to see the abuse both the rods and pistons undergo from this extreme acceleration/deceleration process.
The strains imposed by these excessive speeds can snap connecting rods and crack piston skirts. Another not so serious side effect is that power can be lost due to the piston outrunning the flame front. Piston speed is related to crankshaft stroke, so being able to calculate it can potentially help you steer clear of a dangerous situation before swapping in that stroker crank on your next buildup. (fig. 4
Rich Belloff
