Old 02-11-2006, 02:45 AM   #1
Exhaust Hack
Hey guys, I just hacked my exhaust to make it sound louder.
Details are at http://www.ppbb.com/boards/ppbbphp/showflat.php?Cat=&Board=ARCHIVES&Number=1085350&page=4&view=collapsed&sb=5&o=2&fpart=all
It is possible!
It was pretty rough, but beats paying $1000+ for a sports exhaust, and looks completely original (from the outside).
I've attached (well tried to..) a pic of where i cut the hole to bypass the muffler chambers. (no thats not my exhaust, i din't have to open it as i cut it using the side of a drill bit up the inlet.
steven is offline   Reply With Quote
Old 02-11-2006, 02:47 AM   #2
My pic worked.
Heres another of a earlier exhaust (the one in the previous post is a 2001 exhaust). This shows the passage of gasses through various chambers.
Old 02-12-2006, 09:57 PM   #3
Interesting.
Can you describe the change in the sound. Is it a consistenty nice sound throughout the RPM range?
It seems that quite a long drill bit is needed.
How easy is it to remove the muffler and put it back on?
socratic is offline   Reply With Quote
Old 02-14-2006, 02:32 AM   #4
Refer to this in relation to taking the exhaust off.
http://www.renntech.org/forums/index.php?showtopic=7325&hl=exhaust
its easy to remove apart from the 2 bolts on top... these will test your
patience.
The sound is not much louder, but noticeable. The dead silence that was standard is gone.
If you want it louder drill il bigger. Quieter, drill a smaller hold. The hole i made was aout 1.5cm across.
