Old 06-16-2006, 04:14 PM   #1
KevinH1990's Avatar
Plastic Piece In Front of Rear Wheel
I have a 2000 non-S. I drove over some debris yesterday and cut the driver's side rear tire. The flat tire or debris also damaged the plastic piece in front of the tire. I've attached a picture of the undamaged piece on the passenger's side.
Does anyone know what this part is called? How much should it cost, and where is the best place to buy it? How easy is it to replace?
Thanks in advance for your help.
Painted Bumperettes, 2004 (OEM) Top, Homelink integrated in dash with Targa switch, 997 Shifter, Carrera Gauge Cluster with silver gauge faces, heated 12-way driver & 8-way passenger seats, Litronics, silver console
KevinH1990 is offline   Reply With Quote
Old 06-16-2006, 04:37 PM   #2
Price-wise, $10 to $20. Try Sunset Porsche
http://www.renntech.org/forums/index.php?s=&showtopic=6045&view=findpost&p=40878
98Boxster98 is offline   Reply With Quote
Old 06-16-2006, 06:07 PM   #3
I always thought that part is called the splash guard.
rctboxsters is offline   Reply With Quote
Old 06-16-2006, 06:19 PM   #4
The Piece is called Trim - Satin Black PN# 986.504.393.00C (Lft.) 01C(Rt)
It lists at Auto Atlanta at $25.00. It is actually an assembly of both the Urethane larger piece and the rubber lip PN# 986.504.893.00 list - $7. The 1st part number will get you the entire assembly w/ lip.
All you need to change it is a philips screwdriver and a 10mm socket/wrench. It over/underlaps several adjoining pieces including the Wheel well liner and the undercarriage tray. So study the existing one carefully before removing it. You'll need to remove the wheel well liner w/ the 10mm wrench and swing it out of the way, then loosen the 3 philips screws, swap the piece (again paying attention to the over/underlaps) then tighten everything back up. No need to raise the car or remove the road wheel. Takes less than 10 min. Hope this helps...
Old 06-16-2006, 06:20 PM   #5
I think the part you want is the wheel arch trim.
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=986flap&Category_Code=POTEBXEX
Speed Yellow 2001 Boxster S
xtopher is offline   Reply With Quote
Old 06-16-2006, 06:36 PM   #6
KevinH1990's Avatar
Thanks guys. That should do it.
